Results 1 to 5 of 5
Thread: Can I lift my VRX AWD
    Jan 2015
    Default Can I lift my VRX AWD
    Hi, im new here so be nice.
    I have a 2005 VRX AWD. Fantastic vehicle. I use it for what it was made for and frequent dirt roads. To make life easier I was wondering if anyone made slightly taller springs for the AWD. I'm not after much, maybe an inch at most.
    Any feed back or ideas would be appreciated.
    I believe Lovells make heavy duty raised rear springs for the FWD sedan intended for towing use which would probably raise the height about 20mm at the rear. I have Lovells heavy duty standard height springs all round which reasonably closely approximated the original ride height front and rear. K-Mac I believe can also make custom height springs. Fitting camber/caster adjustable strut tops (e.g. K-Mac) at the front might also get you a few mm there.
    The catalog I have access to online only shows a listing up to TJ model which shows front and rear available for TJ, but I suggest calling Lovell's Tech Help.
    Ring 1800 006 227
    3 years ago, I needed some help finding some coil spring pad height raisers.
    Ask for Mike in the tech help area.
    He is very helpful.
    xboxie's Avatar
    May 2011
    nice, when you lift it can you post up a pic please would like to see it
    macropod's Avatar
    Feb 2010
    Australian Capital Territory
    I have a set of the Lovells CFR-31 (front) and CRR-40 (rear) springs fitted to the front & rear of my VRX AWD and must say they made no real difference to the ride height that I can tell. Measured from the ground, the tops of the arches for the front & rear guards are now about 68cm. What is noticeably different, though, is that the ride is firmer than before. That should reduce bottoming-out over rough ground. The rear springs also compress less when hitching my van to the car.
    FWIW, according to https://www.lovellsauto.com.au/dist.php?d=9, members of the Fast Magna Owners Club get a 50% discount when purchasing direct. I did.
